MF Baler 124
Bill
09-14-2002 07:37:03
I am looking at a 124 baler and was wondering about the good and bad points. I now own a older Mf model 10 thanks
JIMBO
09-16-2002 13:36:27
 Re: MF Baler 124 in reply to Bill, 09-14-2002 07:37:03
I LOOKED AT ONE AND THEN CHECK WITH MF AND THE PARTS WAS ON THE HIGH SIDE FOR ME PLUS THEY DID NOT HAVE ALOT OF PARTS IN STOCK
bbott
09-15-2002 13:15:30
Mine is still running fine and will pump out bale after bale. That is AFTER I went through it and put everything I could back 'in specs'. (It was really abused in its later years)
That's the key, to have everything adjusted properly and well tuned.. In that state I think they will run with any baler in their class.
I think AGCO is still making this model, (or one very, very similar) except it is badged as a Gehl.
-- bbott
Tim(nj)
09-15-2002 14:59:35
 Re: Re: MF Baler 124 in reply to bbott, 09-15-2002 13:15:30
All current AGCO offerings are Hesston-designed centerline balers, sold under the Hesston and New Idea brands. Gehl is not part of AGCO. Gehl did build a small-square, but quit a few years ago.
JW
09-15-2002 10:34:52
i have one and I will put mine in the feild with any other brand .the last time I baled 1200 bales it missed two ties as far as parts I go to massey dealer and get what Ineed. I had a little trouble with it once I myself threaded it wrong and it would miss one out of every four. the string tension is critial. the knotters have the least moving parts than the other baler including the model10 I like mine very well Jerry
JW
09-15-2002 10:32:34
Jim.UT
09-14-2002 21:59:39
I've been battling a 124 all summer. I may actually have it ready to work again, but I'll have to wait until I have hay to bale before I know for sure. Good point would be if you can get it really cheap. Otherwise, look for something else. Bad point: parts are hard to find and expensive. The knotter is a different design than most other makes and that's what has been giving me headaches. On the other hand, if you are already familiar with MF balers, maybe you'll be OK.
