Windrow gathering wheels for a Hesston 5540
David
09-12-2002 09:39:22
Does anyone know of a source for after market gathering wheels for a Hesston 5540 round bailer or where used ones can be found. I have been told be the dealer that there are no longer available in a kit and I did not what to be each piece seperatly.
Thanks for any help
jamie bentley
09-13-2002 23:41:56
 Re: Windrow gathering wheels for a Hesston 5540 in reply to David , 09-12-2002 09:39:22
IHAVE A HESSTON 5530 NOT SURE YOUR BALER IS LIKE MINE MY GATHERING WHEELS ARE MOUNTED ON 2" PIPE COMING OUT FROM THE L & R SIDE OF THE BALER . mY FATHER CAME UP WITH THE IDEA Of using some old nylon corded 16" truck tires one tire cut side walls uot as close to the tread sa you can put the inside side of tire toward windrow. my gathering wheel hubs have sloted holes around the out side of the hub i used 1/4 bolts 2 flat washer and nut per slot mine work great!
jamie bentley
09-13-2002 23:41:15
