Reclaiming old cut over land
rhudson
09-04-2002 20:55:01
need some free advise fellows. just purchased land that was cut over about ten years ago. most of it has regrown in sweetgum trees that are from 3/4 to 2" in diameter. i intend to reclaim most of the land for cattle pasture. replant trees on some of it. its too rough for my bushhog/tractor (rhino 6 foot). i am dozing some of it, but with my budget that will take years. someone mentioned using a large disk? how about using a herbicide? i hasten to mention acreage because you big fellows will laugh at me. (80 acres)
also, what do i follow up a dozer with to smooth and bed soil for no-till fescue/clover seed? someone mentioned a box/blade scraper with shanks.
Thanks for the help.
read me
11-27-2002 16:04:20
 Re: reclaiming old cut over land in reply to rhudson, 09-04-2002 20:55:01
buy and old dozer that runs with a bruch rake that cuts down into the soil about 4 inches. tear out the little stuff pile in windrows dry and burn. try not to break the dozer , don t push it too hard. speard grass seed on the torn up surface, fence and put some livestock on it this spring. fence and \\\ then sell the dozer for what you have in it. bill h
Glenn Neumann
09-07-2002 05:20:32
I also have a Rhino mower but it is a heavy duty model rated to 4" diameter "brush" and it has a slip clutch. It works great. Only problem is when you encounter a clump, ie. many stalks together. We have a 10 acre field that we reclaimed. Mowed it 1 or 2 times a year for 5 years to keep regrown shoots from starting trees. This allowed many stumps to die out. We have a Case 530 backhoe and used it to dig up the big stumps. Piled them up in hedgerow as a fence. Also pickup any larger stalks by hand as they will wedge in plow (if use more than one bottom) We had to moldboard plow in 1st gear very slow as semi-mount plow will cause front of tractor to lift (and possibly flip over) Added weight to front of tractor (two old NH77 baler flywheels) but still was not enough to 100% gaurentee front would not lift. When we found a stump (or rock) that plow caught onto, then mark it with a plastic shopping bag with rock inside so that later can come back with backhoe & dig out. It may be possible to use a single tooth subsoiler to bust up the stumps. Next year plow 90 degrees from 1st direction (if possible) Goats are a good idea too they love to eat the leaves off the trees.
Punchie
09-06-2002 04:44:33
HI
Boy that can be a lot of work, 80 acres.
By cut over, I'm guessing there are logs in the mix and tops. Hard on the equipment.
I would go with the clear around the edge and fence it in with a good fence. Next would look at what type of plants are there, from trees to weeds. If I would put live stock on it . Goats love tree and some weeds. Cows need grass and may be aloud to eat a few tree ( type and amout you need to check), but you may need to feed hay or grain or both. Pigs, better have a supper good fence and feed them to come to you if they would get out, but they would be the best , smart and would not, in most cases eat any thing that would kill them. The roots would be loosened and the weed knot down, ground tilled. You may find a way for them to plant small areas for you. Fence in a area a strip of ground and let them have at if and at the end of them turning it up side down , lime some and broadcast some seed and see what happens. Maybe use some mulch hay, may seed it for you.
A moldboard plow, not a good idea, spend most of your time cleaning it out a make a big mess of plowing, break a moldboard etc.
I would not use a harrow, if there is any thing that can get stuck in it. You will spent all your time cleaning out the harrow.
Rubber tires , if any one was cutting trees. The stumps from the 3/4" - 1" if cut wrong go right though the back tractor tires.
Good luck !!
Punchie
bill
09-06-2002 13:20:57
 Re: Re: reclaiming old cut over land in reply to Punchie , 09-06-2002 04:44:33
There is actually a company in New Hampshire that 'rents' a flock of sheep to do land clearing and maintenance where humans would rather not tread.
Sewerage plants for example. They have been used in Carlisle & Concord MA the last two years on conservation properties and I think in the National Park in Concord.
chaney creek
09-05-2002 19:38:19
If you take it slow, keep your blades sharp on your cutter, set your draft on light to let it bounce a little you should be able to at least cut the gum saplings up. Sometimes you have to push them over and the set the cutter down on them slowly. I have an Int'l 454 diesel (38 h.p) and used a five foot cutter and leveled an eight acre field.
Have you thought of using a turning plow - maybe a three bottom. It will bury the trash.
Have the original cutover stumps decayed?
Burrhead
09-05-2002 09:09:25
Just remember that if you use herbicide the stuff that will kill trees and brush will also kill clover.
That's a dang good choice for cattle by using clover and fescue but I've tried planting it both ways and did'nt see any advantage to using no-til methods.
Around here we use tractors for doing that kind of ground work. An offset gang disc will take out 2" saplings and also smooth the ground if you put a drag behind it to fill in the rough spots.
The going rate is $10 per acre around here for bigger tractors with new ground disc.
ferrell freeman
09-05-2002 08:31:24
I,donot know what part of country you are in . Iam,in FL. around here and in most parts of the country there are contactors who large drum choppers in cut overs first then burn and harrow the burned site . Most of them do it them do it by acer .
ShepFL
09-05-2002 09:22:13
 Re: Re: reclaiming old cut over land in reply to ferrell freeman, 09-05-2002 08:31:24
I agree with with Ferrel has said. I am currently doing a reclaim on nearly 100 acres. I have had part of it done with a dozer (trees to big). Forest Service used to do this for nominal cost but now cost is getting prohibitive ~$120/hr.
Regardless, now I have large slash piles to clean up - PITA.
For the balance I plan on using my backhoe with a root rake on the front end. Cheaper for me since I own backhoe and had to pay for dozer work. Planning to follow root raking with 10' IHC #37 disk harrow. Some of the less grown up areas (25 acres) I have bushhogged and this weekend I will be using disk plow to plow the ground then disk again.
Be prepared for lots of hard work!
ferrell freeman
09-05-2002 08:26:20
Bob
09-05-2002 06:50:26
My Dad sold Farmall F-30's on steel wheels with the #47 3 disk plow with 28 inch cut out disks on it to clear new ground. Doubt you could find one today. In later years what we called a Bush & Bog harrow was used. Either an Athens or Taylor-way. Usually 16 0r 20 disks that were 24" cutouts.
Fred Zelch
09-05-2002 07:14:59
 Re: Re: reclaiming old cut over land in reply to Bob, 09-05-2002 06:50:26
We cleaned up some cut-over ground with a John Deere 60 and a wheel disk. Over inflate the tires so the dead stubs will tend to slide off instead of puncturing and go SLOW. Good luck.
Charles Story
09-05-2002 05:17:09
After dozer work, put a spring tooth hare/new ground maker on it and watch what happens. If you have the HP. I had a 20' spring tooth hare to much for ford 3000 so I took a 5' sction out, fab. 3pt. hitch. Had about 4 acres grown up in trash trees, dropped in right after dozer finished had it looking nice in no time. Also, I have a two bladed (bell plow) which I use to subsoil, it is good for turning up small stumps. After using it I lightly disc then run spring tooth hare to clean off trash. good Luck.
paul
09-04-2002 22:33:15
There were large heavy disks - nothing like you buy now - that roughed up & cut up this type of land. Need a Cat to pull, tires don't (or do I guess!) cut it.
A 'disk plow' might work for you, but sounds like still tough on tires to me.
Herbicides will kill a lot, but you still have the woody mess on the ground, didn't really accomplish anything...
An option is to fence it & get livestock on it, they help take down a lot of green stuff, get the process rolling. I hear goats clean things up the quickest, if you have a mind for such creatures. Then you can at least see what you can bush-hog & what you can't, rocks & such...
I do not understand the concept of 'no-till planting' when you talk about following a dozer. you have done some _major_ tillage there, what's up with trying to go no-till at that point? :) Just kiddin' with you, struck me an different. :)
--->Paul
rhudson ok Paul, you got me.
09-05-2002 15:20:37
 Re: Re: reclaiming old cut over land in reply to paul, 09-04-2002 22:33:15
now that i read my post, it is kinda funny,,,on the other hand you just don't know how tight our clayey soil is in southern virginia!
