John deer round baler loose looking bales
garry
09-03-2002 20:46:26
its a mod 500 with new belts and it has a bale kick on it is there any way to get tighter looking bales,its got hyd tie and seems to be tieing ok???
Roy in UK
09-06-2002 12:00:22
 Re: john deer round baler loose looking bales in reply to garry, 09-03-2002 20:46:26
I used to use a JD 550, and inside the front twine box was an adjusting screw to increase the density of the bales..... I dont know if it is the same on your baler. the JD can make very dense bales!
garry
09-06-2002 20:16:39
 Re: Re: john deer round baler loose looking bales in reply to Roy in UK, 09-06-2002 12:00:22
nope i looked 2 in that box nothing there except twine, but thanks anyhows
Roy in UK
09-06-2002 11:57:56
Kerry
09-05-2002 15:25:26
If you're pulling it pretty fast, the bales will be a little loose. They're ok, just ugly. You can try slowing down a little, or try this trick I discovered with ours - if you stop and let it turn for about 30 seconds before you dump it, it will tighten up some.
