Mod 500 john deer round bailer makin loose bales
garry grohn
09-01-2002 19:32:48
how do i get this this to make nice tight bails i put new belts on and it, and it seems to be tieing ok, but still makes a floppy looking bale im running on a 125hp tracktor is there any other adjustments i could make to tighten the bails up it has a bail kick on it if that makes any differance, thanks
Jim
09-02-2002 04:38:49
 Re: mod 500 john deer round bailer makin loose bales in reply to garry grohn, 09-01-2002 19:32:48
Garry,if it is a JD 500 it only uses spring tension for bale tightness.You can slow ground speed,make smaller windrows,run at rated pto speed,or add more springs.Later model JD balers had dealer installed extra springs(410).I never saw a bale kicker on a JD 500.Only other option I see is to trade it for a baler with hyd. tension(much tighter than just spring tension).Jim
garry
09-03-2002 20:53:44
 Re: Re: mod 500 john deer round bailer makin loose bales in reply to Jim, 09-02-2002 04:38:49
thanks for the tip ill try to tighten them springs up and go a bit slower ill let you know in the next week to see if that helps,,,garry as the bail kick go,s i must have the only one lol i never seen any of them with them on, i guess im lucky lol
