NH 270 baler shear pin problems
Joe Baler
08-31-2002 20:26:57
Hi,
I have a New Holland 270 square baler, recently been having problems with shear pins breaking. Baling short dry wheat straw in evening - everything was working fine. But tried baling the next morning when straw was a bit tougher, would tie 3 or 4 bales and then bust a shear pin. This happened about 3 or 4 times.....then ran out of shear pins and I gave up! Any idea what the problem might be?
Dan
09-02-2002 09:41:59
 Re: NH 270 baler shear pin problems in reply to Joe Baler, 08-31-2002 20:26:57
Jim had lots of possibilities. Straw can be really tough to bale especially if a bit tough. Your choice is to back off on tension but then you get loose bales. Could be that needle safety block is out of adjustment so it is hitting the plunger arm or the needle brake could be worn or out of adjustment allowing them to drop slightly to allow the plunger safety stop to engage. I had an old IH 56 at one time, no matter what you did you couldn't bale decent straw bales. Oh one other thing, you can remove the restrictors in the bale chamber.
Jim
09-02-2002 05:04:46
Joe,are the plungerhead knives sharp?If your baler has bushings where the shear pin goes they could be getting worn.Have you checked the timing lately?A chain that needs tightening a little can cause the timing to be off enough to make it shear the bolt.It is difficult to make a straw bale to heavy.Jim
Eaglewerks
09-01-2002 23:25:32
I have a NH 273 Hayliner. I can guarantee I will break a shearing flywheel bolt if I try and bail too heavy a windrow. Too much hay at one time will cause the pin to shear.
The NH Owners Manual also suggests the following:
Problem: Shearing Flywheel Bolts
Cause: Bailing too heavy
Solution: Loosen bale tension
I simply make my windrows smaller so I continue to make the same weight bale as I normally make.
brandon
09-01-2002 07:30:34
wait for the hay to dry out
brandon
09-01-2002 07:29:54
