Rear scoop for 3 point
Scottey841
08-28-2002 21:54:00
I have read on some postings about a rear scoop/bucket that goes on a 3 point hitch. Does anyone have any info on these? Brand names? Are they still in production? I have seen a small one in the Northern Tool catalog but I was thinking of something bigger. Thanks
John ,,here tis.
08-31-2002 17:24:28
 Re: Rear scoop for 3 point in reply to Scottey841, 08-28-2002 21:54:00
Gnuse manufacturing of Arlington Nebraska, manufactures several sizes of rear mount 3pt. scoops. Dark green, hold up real well. Been making them for at least 20 years. john
will
08-31-2002 13:37:05
I RAN THEM GROWING UP ON THE FARM FORD AND MASSEY FERGUSON THEY HAD HANDLES NOT THE ROPE ONES THE HANDLE WORKS BETTER WE USED SOME WITH ROPES THEY WERE ROUGH ON YOUR HANDS WE DUG DITCHES AND A 2 ACRE POND 7 FOOT DEEP RUNNING 5 TRACTORS ONE SUMMER WHEN WE HAD LAYED BY THE CROP THE WERE SLOW BUT THAT WAS ALL WE HAD AND PLENTY OF FARM HELP
hay
08-30-2002 04:13:14
call around to some of your local tractor dealers.a lot of the time they have good used name brand equipment. that junk that they sell at tractor supply company is just that,JUNK. i only buy a major name brand so i can get parts/service later if i need it. it's actually cheaper in the long term.be safe!
Yankee in Tn.
08-30-2002 04:07:20
I bought a 30" from my local Co-op for $190.I've found them better priced than TSC on almost every item they sell.It's A very useful tool.
PHILIP
08-29-2002 07:34:01
I HAVE A 30" KING KUTTER FROM TRACTOR SUPPLY WHICH I USE ON MY FORD 8N. GREAT FOR MOVING PILES OF DUMPED GRAVEL OR DIRT. I HAVE ALSO TAKEN DIRT FROM A FIELD FOR RELOCATION. POOR MANS FRONT LOADER @ $275. PHILIP.
Chuck, WA
08-29-2002 15:08:07
 Re: Re: Rear scoop for 3 point in reply to PHILIP, 08-29-2002 07:34:01
Oops! Right you are...the bigger King Kutter is 30", not 36" as I said in my earlier reply.
PHILIP
08-29-2002 07:33:10
Chuck, WA
08-29-2002 06:26:54
I have one borrowed from a friend. It's a Ford that undoubtedly was bought with his tractor years ago - not sure if Ford still makes them. However, our local Ranch & Home store carries King Kutter implements and they make two sizes - one 24" wide and one 36" wide.
The Ford scoop I'm using is 24" wide. I use it on my MF35 diesel. It is as described in another reply. You dump it by reaching back and pulling a handle that sticks out from the top of the frame and trips a catch - I suppose you could attach a rope or chain to make that easier. Dumping can be difficult depending on how the load is balanced. If it's not balanced with most of the weight in the open end of the bucket, you need to physically push or pull the handle to dump, not just trip. If it's balanced right, just trip and it dumps. We shoveled into it and filled the bucket, and it was very difficult to dump, but when we just backed into a pile of dirt to fill, it dumped easily. The difference was that shoveling into it, more dirt was at the back of the scoop, and when backing in, more was at the front...balance was different.
It is extremely useful. However, it's not for digging into a level surface. You can do that to some extent by adjusting your upper link toggle to tip it downwards, but even then, it doesn't dig in well. In loose dirt, it does really good.
The only problem I had was trying to use it to dig a shallow trench with the bucket tipped down, but facing forward. As you might expect, it dug in and when it caught, the bucket continued to rotate up and over into my upper link toggle, bending and breaking it in two. Being more of a tractor newbie at the time than I am now, I was embarrassed that I broke an almost new link toggle before the shine was even off, but I did learn a lesson from it and it won't happen again.
In any case, a very useful implement.
Chuck, WA
08-29-2002 06:25:23
Charles Story
08-29-2002 05:24:51
Very handy item, somehow I now own two of them. I purchased a MF 135 with 10 Implements and just so happens a dirt scoop was thrown in the deal.
Paul R.
08-29-2002 03:12:59
Got one from a yard sale for $100, very useful. Tractor Supply sells 'em new, around $250 I think.
It's basically a big steel shovel with an overhead frame that lets you attach it to a 3-point, facing either forward or back. You can scrape along your driveway or yard going forwards, picking up loose gravel, dirt, etc. Turn it around, and you can back into a dirt pile, big rocks, firewood, anything, pick it up, carry it anywhere and dump it where ever you want. Very useful for heavy engine blocks, generators, anything you need to move. I've used one on my Ford 8N, lifted so much that the front wheels came up off the ground.
I've only seen one basic size sold, whatever brand you look at. They're a good investment.
