Will a Dearborn mower fit on a Super C
Farmer Bob
08-27-2002 21:55:14
Need to know if a Model 14-4 Dearborn sickle bar mower will mount onto a Farmall Super C? Any modifications that have to be made?//TIA//FB
greg
09-08-2002 12:37:00
 Re: Will a Dearborn mower fit on a Super C in reply to Farmer Bob, 08-27-2002 21:55:14
Farmer bob, I can't help you. but can you help me? I'm looking for all the info I can get about 14-4 mowers. Greg
Paul R.
08-29-2002 03:23:48
Don't know for sure, but I'm thinkin' no. The Dearborn used the 3-point on the Ford, and even then you have to remove most of the standard linkage and replace it with special arms that came with the mower. They're a bear to attach to the tractor, even the one they were designed to fit! I think a better fit bould be a semi-mounted unit, one with a caster wheel on the back. If you have a 3-point on the Super-C, I'd still look at a newer design that went on easier. Good luck.
Paul R.
08-29-2002 03:22:08
