REPLACEMENT JD PLOW WHEEL
C.M.RICH
08-24-2002 20:33:40
DO ANY OF YOU GUY'S KNOW WHERE I CAN FIND A REPLACEMENT 3-BOLT PATTERN WHEEL FOR A PULL-TYPE JD-612,JD-613 PLOW? ANY HELP IS APPRECIATED,THANKS,RICH IN S.C.
Bill
08-25-2002 18:33:01
 Re: REPLACEMENT JD PLOW WHEEL in reply to C.M.RICH, 08-24-2002 20:33:40
Try B W Macknairs 717 543 5136. Tell them Bill Christoper in Okla sent ya. Here thats called a tail wheel. Good luck
Bob Collins
08-25-2002 19:01:10
 Re: Re: REPLACEMENT JD PLOW WHEEL in reply to Bill , 08-25-2002 18:33:01
He didn't specify the location of the wheel he needs, but it appears he has a #52 plow and all 3 are held on with three bolts. If the source you gave is a long way off, a scrap yard might be a good place to look and of course the next swap meet that comes along.
C.M.RICH
09-05-2002 08:24:32
 Re: Re: Re: REPLACEMENT JD PLOW WHEEL in reply to Bob Collins, 08-25-2002 19:01:10
THANKS GUY'S, THE WHEEL I'M LOOKING FOR IS ON THE RIGHT SIDE,3-BOLTS HOLD IT ON, THE LEFT SIDE HAS A REGULAR 5-BOLT WHEEL AND THERE'S NO WHEEL IN THE REAR OR A PLACE FOR ONE THAT I CAN TELL? THANK'S C. M. RICH IN S.C. I WAS ALSO TOLD TO CHECK WITH MACKNAIRS 717-543-5136 IF THIS HELPS ANYONE ELSE WITH PARTS ON THIS SITE.
