JD 346 balers
Jesse
08-23-2002 19:32:26
what size bales does a JD 346 baler make? i think it is a 14x18 just like a 336- also how many plunger strokes per minute on the 346 compared to the 336?
Rick
08-25-2002 06:54:02
 Re: JD 346 balers in reply to Jesse, 08-23-2002 19:32:26
These are same balers. The 336 just has 61 inch wide pickup. 1976-81. The 346 was a wider pickup 71 inches. Same years 1976-81. Both made same bale and have same plunger speed 80. I have 327 for sale if interested. Same baler just newer 1982-88
JD Merl
08-23-2002 19:38:03
The 336 and 346 are the same size balers . the only different is 346 is wire tie , and 336 is twine, Hope this helps!!!!
Tim(nj)
08-23-2002 20:42:24
 Re: Re: JD 346 balers in reply to JD Merl, 08-23-2002 19:38:03
No, this info is erroneous. The 336 and 346 make 14"x16" bales, and both were available in either twine or wire versions. The 346 has a wider pickup, a larger feed opening, and some heavier components in the front end (clutch, etc.) than the 336. I don't remember for sure, but the 346 may also have a faster plunger than the 336, but not a lot faster.
gy3020
08-24-2002 05:51:03
 Re: Re: Re: JD 346 balers in reply to Tim(nj), 08-23-2002 20:42:24
Right on Tim, Don't know where JD merle is getting his info but I had both a 346 twine and still have a 346 wire. The 346 is the heavy duty version set more for those of us who are custom baling for higher capacity. Its a darn good baler too!
Bill
08-23-2002 21:31:40
The 348 has a stoke of 93/min verses 80 for a 336.
