John Deere #5 mower
Dave
08-22-2002 05:47:44
I recently aquired a 7 foot JD sickle bar mower. It is chain driven through two gear boxes. It is very good condition wise. I am told that it is a #5 but can not find a model number on it. How are these mowers identified?
Thanks for any help.
Bob
08-23-2002 11:56:19
 Re: John Deere #5 mower in reply to Dave, 08-22-2002 05:47:44
#5 mower looked almost home-made... triangular frame made out of ANGLE IRON... this was replaced by #8 mower, which had a more refined look to it... CHANNEL IRON frame. #5 mower has ratchet slip-clutch in the open, in PTO shaft next to chaincase. #8 mower has slip-clutch enclosed in rear upper part of chaincase. When you hit obstacle with #5 mower, 1 side of whole frame releases, and swings back. On #8, the safety trip releases only the cutter bar. Feel free to email if I can be of any more help.
Mark Meyer
08-23-2002 05:03:41
Dave,
I have had a #5 for a few years. It was a rusty piece of scrap metal when I bought it but I've got it up in pretty good shape, including new paint. It works like a new one. The site that Jerry was talking about was www.retiredtractors.com
Let us know if you need any help getting your mower working.
Mark
Jerry S
08-22-2002 13:22:15
The numbers on some cast parts will help do that. I know that a #5 will have the single wheel on the back end and were originally built to have two attachment points (via bolts to L shaped pieces) on the tractor. I believe the others attach differently or have different bar lengths. I think there is a site maybe called Rummey's that has a pic of one working. There might be one in the implement photos here too.
John Ne.
08-22-2002 22:54:33
 Re: Re: John Deere #5 mower in reply to Jerry S, 08-22-2002 13:22:15
The No.5 mower used a pto driven cast iron gear case bolted into the mower frame, this is about 26>?inches long, the pitman arm is driven by a cast steel flywheel off the bottom of this gear case. The gear case is filled with oil. Made them rather unique among old mowers. john in ne.
