Paul
270, twine loose knotter
Garry
08-19-2002 18:33:37
Paul,
Well stated on the bad/no twine issue, they ought to 'string up' whoever it is in quality control that lets 'such' out the loading dock. Can make for a very trying/disgusting day!!
But, you have raised another question for me and the 'old blue baler' that I've been getting ready to go with..... both sides of the knotters were 'loose' as you described, now I am wondering if it was 'on purpose' as the nuts were 'lock nuts'.....thought it was just another case of not keeping all the bolts 'tight' and have tightened them down cause I couldn't see no reason for 'em to be 'loose'.
Perfect ending for a Monday!!!!! will keep that in mind if I have trouble -- IF I ever get to the hay field..... ....Thanks
Garry
Rick
08-21-2002 06:06:45
 Re: Paul - 270, twine loose knotter in reply to Garry, 08-19-2002 18:33:37
When you guys tie your string balls or poly balls together I always use a square knot,make it as small and tight as possible, then cut any of the little ends from knot off. I have done this for over 11 years. Our normal average for broken bales is 3 to 5 a season. 4000plus straw and 5to 6000 hay. They are usually tied the poly gets pulled off side by accumulator. I won't use string because of too many impurities,I use only poly twine from one company and only one certain knot size. Running JD and New Holland balers both tying excellent. NEw Holland only run late model of those otherwise you need to cheat on tension on one side or it will make banana bales.
Rick
08-21-2002 05:56:22
JMS
08-20-2002 14:12:39
Those bolts were indeed 'lock nuts'. Do not tighten them down to where they are mounted- they need to be able to move, thus the use of locking nuts.
JMS/MN
08-22-2002 16:30:25
 Re: Re: Paul - 270, twine loose knotter in reply to JMS, 08-20-2002 14:12:39
Might need to be loose in case the needle flexes a bit as it goes through the hay in the bale? Only know they need to be loose- for an in-field repair when no locking nut is available, leave them loose and double nut them.
PS - twine changes??
08-19-2002 18:54:32
Paul,
What 'type' knot do you use to tie the ends of successive twine balls together ?? My 273 will generally 'miss' tie also when the twine changes to the next ball. Doesn't hangup in the needle eye, or anywhere else, just flat will not tie when the new ball starts. Next bale and thereafter is okay. Have decided that it is a case of twine overrun/slack past the twine tension bracket when the joining knot clears??
Garry
paul
08-20-2002 22:56:44
 Re: Re: Paul - 270, twine loose knotter in reply to PS - twine changes??, 08-19-2002 18:54:32
I use a square knot, shortest ends possible. I think I run a pretty tight bale, and the knot will hang on the hay & pull out of the knotter is my biggest problem. Really ugly things happen when the knot happens right where the bale knot is, but that is quite rare.
As to the loose bolts, they appear as if they should be tight, but it works better when they are loose. One of those things that just works fine this way, so I don't try to question or mess with it. :)
--->Paul
mistie reasons......
08-19-2002 20:06:59
Done typed it out twice, the ISP kicks me off and when they do that it locks my 'puter up!!
The short version, about the best I have been able to decide for myself and my 273 - before the curser quits blinking again!!
15% - twine quality
25% - who knows??
60% - operator error
Garry
