Twine for 24T Baler
grainbuyer
08-19-2002 17:07:35
Has anyone used plastic twine for a 24T baler. And if so what size 9000 or 10000? Did it work better than sisal?
Thanks
grainbuyer
david
08-21-2002 11:58:59
 Re: Twine for 24T Baler in reply to grainbuyer, 08-19-2002 17:07:35
I switched from 10,000 sisal to 9000 plastic about 4 years ago on a 336 (very similar knotter). Didn't change any of the adjustments. Still misses the first 2 bales of the season and about one every 400, just like it did since it was new. I can live with that.
grainbuyer
08-21-2002 17:35:38
 Re: Re: Twine for 24T Baler in reply to david, 08-21-2002 11:58:59
Thanks for all your feedback guys....I went and got some 9000 plastic today. Will be trying it early next week I think, weather permiting
phil munson
08-20-2002 10:19:50
I do not get it, but that is not unusual. I had a JD 224T, and am told it is the same knotter. We use both plastic and sisal twine. Seems that tension was increased on twine discs a little when we started with plastic; other than that no changes were made. If the needles are adjusted to bring the twine close enough to the billhooks to make the knot there should be no problems.
lc
08-20-2002 13:07:07
 Re: Re: Twine for 24T Baler in reply to phil munson, 08-20-2002 10:19:50
The problem I had when using plastic was that the gap in the billhook wasn't small enough to hold the ends of the string, not pulling the knot tight enough to stay tied when it released. A less worn or different model would probably make all the difference in the world. A gap only .025" smaller could be all it takes. I switched to the 170lb. plastic and it works great.
jim
08-20-2002 07:13:05
I think you'd better check with a JD dealer because an older baler may not have the correct bill-hooks to handle plastic. I've used plastic since 1972 but my NH 268 had to have the bill-hooks changed in order to handle plastic. The newer balers will handle both types , however , the newer plastic twine is sized closer to sisal and the older balers might just handle it.
Chris Brown
08-20-2002 05:12:52
I use plastic string in the 14T , it tends to cut half way through sisal twine by the knot.made nearly 2000 bales this summer and broke 10 I blame on the baler.
Chris Brown
08-20-2002 05:12:41
Chris Brown
08-20-2002 05:12:27
Rick
08-19-2002 18:23:52
I switch from string to plastic about 10 years ago and would not go back. I use 170 not strength plastic. I comes in 9600 to a box. The new released type comes in 7200 single rolls. They make 140 knot strength also you can find this in any farm store. The 170 knot you won't find in stores very often. I also sell it if you need to try it. I run it in 327 Jd baler with excellent results and did no adjusting other than put on new set of knifes in knotters. You should find the plastic will be cheaper in price also. Where are you located. Let me know if I can be more help. 327jd baler is for sale.
