RED FORD BAILERS
Dave in AL
08-18-2002 19:14:26
Just found an older ford hay bailer at a neighbors farm. It looks to be in good shape.It has been sitting for around 3 years Are parts still eaisly obtained and were they any count too start with thanks in advance
Errin OH
08-19-2002 07:28:47
 Re: RED FORD BAILERS in reply to Dave in AL, 08-18-2002 19:14:26
I am running a 14-80 - mid 50's? - PTO driven. Works realy good. Only problems I had so far is learning that these old bailers do not and can not be operated like the newer ones. You run it up on a full 540 pto speed and she never work right. You will have to start slow and find the right combination ground speed and pto speed. In my case its 1st gear at 900-1100 rpm. (53 NAA) As for parts, not really sure. So far I have been able to get everthing I needed. But then again it really has given me any trouble. The pick up teeth can be found at a NH dealer, just take an old one with you so they can match it up. Knives are a little harder to get, had to order from an old stock dealer. (50$ each). I got really luck when I got this baler. I knew nothing and really didn't expect much out of it for a 100$. (More learning than baling) But boy was I suprised, this old thing just keeps going and going, and I only have 250$ in it.
Jerry
08-19-2002 00:05:24
I have 2 red ones model 250 one is type 14-76 engine driven 2-cyl wisconsion TDF the other is type 14-80 Pto driven most parts are availabe replaced some pick up tines on the 14-76 this year but did have to have a knoter haft machined the only thing that i know that is not interchangabe between the to is the pick up tines plan to retire the 14-76 this winter and put the engine on the 14-80 have been execellent balers also picked up an old New Holland model 66 a few days ago hav not realy examined it but the knotters look like they might interchange Jerry Wa state
paul
08-18-2002 22:58:48
Red???? Thought they all were blue. It is not a "New Holland" baler is it?
Model number in any case would help a lot, different models, different answers.... ;)
--->Paul
