Over running clutch
Scott 841
08-14-2002 18:33:05
I bought an over running clutch and went to install it and it doesn't have any instructions. It came with a roll pin and has 2 set screws 180 degrees apart. It looks like I am supposed to remove the set screws, align the holes in the clutch with the hole through the PTO shaft and drive the roll pin in where the clutch will still free wheel. Then put the set screws back in. Does this sound correct? I can't imagine that the clutch is just supposed to slide on and stay there without the pin. Thanks
Mike
08-14-2002 18:41:08
 Re: Over running clutch in reply to Scott 841, 08-14-2002 18:33:05
Scott,
You got it.
Scott 841
08-14-2002 18:43:03
 Re: Re: Over running clutch in reply to Mike, 08-14-2002 18:41:08
Thanks Mike.
