J.d. #44 plows adjustment for trip
Pete
08-14-2002 10:54:26
My plows trip up fine but when I try to trip them down to plow they won't. But, if you get off the tractor and pull the rope at more of a downward angle the plows will trip ok. Is there a adjustment I can make somewhere to fix this
Bob Collins
08-15-2002 16:00:12
 Re: j.d. #44 plows adjustment for trip in reply to Pete, 08-14-2002 10:54:26
Pete, My experience with this problem is that over the years the horizontal part of the trip lever has twisted some and the rope just doesn't pull at the correct angle. The easy fix is to heat the vertical portion of the trip lever in the center and bend it back about 30 degrees or as much as is appropriate, so that a tug on the rope will drop the plow. There is another possibility, and that is that the clutch is dirty and thus sticking inside, in that case a temporary fix is to just stop at the beginning of the furrow , pull the rope and when it drops go on down the field. Of course a good cleaning and a little lube wil fix it "better". HTH Bob
Hey!! Wake-up need help!!!
08-15-2002 11:23:22
Does anyone know? I know there's some old farmers out there who have used one of these.
