What type of plow did I buy? (2 bottom, tow-behind)
Rick K
04-13-1999 07:20:07
I bought a plow, but have no ideal what it is. It is a two bottom plow. The paint is mostly gone, but there might be green reminants. It has two tires/wheels (16"). The coupler appears to be of the type that should grab onto a ring. There is a big crank on the left side, facing forward, that looks like it has something to do with adjusting the depth. There is a lever, about two feet long, with teeth on the bottom that can engage into sort of a sprocket-like thing on one of the wheels, that I believe is used to automatically raise the plow out of the ground for transport. There is a metal wheel on the back. Any ideas on what I bought?
denny
04-19-1999 15:05:26
 Re: What type of plow did I buy? (2 bottom, tow-behind) in reply to Rick K, 04-13-1999 07:20:07
sounds like an oliver.i have one but i turned it into hydrolic lift
Norm
04-14-1999 18:01:47
Oliver, the they were the only one who made that arm with the notches on like that.
Norm
Tom
04-13-1999 17:30:20
How many bolts hold the wheels on?If only four most likely a JD.
paul
04-13-1999 09:49:39
I would suspect an Oliver, which were popular in my neck of the woods. I have a 2-16 as you describe, and a 3-16 with a rubber rear wheel sitting here. E-mail if you wish to for more.
--->Paul
