Rex Silage box
Lance
08-13-2002 09:55:54
Has anyone ever had trouble with the main apron chain feeding on a Rex silage box. When the box is empty it will advance just fine.. but when it is half full or totally full.. it won't advance.. any thoughts??
JMS/MN
08-13-2002 23:18:22
 Re: Rex Silage box in reply to Lance, 08-13-2002 09:55:54
Might be a key stock sheared in the main drive- with little resistance (light load) it will advance the chain, but under load the gear inside the gearbox rotates on the shaft going out to the apron, but does not connect to the shaft. If that's a worm gear drive, could be either gear, or even something on the input side, ahead of the gearbox. Start looking on the outside and eliminate all possibilities, working your way into the gearbox.
