Shear bolt loosening
joe
08-12-2002 18:09:59
have a IH brush hog model 211.not exactly sure but shouldnt matter. very heavy duty. the shear bolt is loosening up every day regardless of bolt kind etc. tightened as tight as i can get it. all other joints are tight too. dont understand. no areas to cause excess vibration to do this. any solutions?? can take digital pics to show area for those who may have answer.
db
08-15-2002 18:31:09
 Re: shear bolt loosening in reply to joe, 08-12-2002 18:09:59
also might try a backing nut and "lock tight"
Mike in Houston
08-12-2002 19:46:44
Put a second nut on it and tighten the two nuts against each other. You'll be able to get it off that way if you need to with wrenches. Another way which I've seen my father do it if he "NEVER" wanted to it come off again, hit the end of the bolt after the nut has been put on to "mash" the threads on the end. Hit it on the edge of the bolt. I promise it won't back off all the way then but you'll probably need a cutting torch to get it off to work on it.
paul
08-12-2002 21:15:05
 Re: Re: shear bolt loosening in reply to Mike in Houston, 08-12-2002 19:46:44
Has it sheared a number of times & made the hole(s) deformed - out of round? That's the condition my baler is in, bolts loosen all the time. I use lock nuts - nylon are ok, but the stamped ones are better. Works for me.
--->Paul
