Ledger plates, installing new
Farmer Jack
08-12-2002 14:03:40
What's the best method of installing new ledger plates for a JD #5 mower?
Dan
08-14-2002 21:47:02
 Re: Ledger plates, installing new in reply to Farmer Jack, 08-12-2002 14:03:40
I usually grind the bottom of the guard in the area of the rivet to expose it better then using a punch about the size of the rivet knock the rivet out. Far from a fun job. Replacing them is a little easier but you need something to put against the top of the rivet while you flatten the bottom. If there is a better way I would like to know also.
Bigdog
08-13-2002 03:34:48
It depends on who you talk to. Some like rivets, some like bolts.
RickB.
08-13-2002 17:18:09
 Re: Re: Ledger plates, installing new in reply to Bigdog, 08-13-2002 03:34:48
Forgive me for asking, but how does one go about BOLTING a ledger plate onto a guard?
