John Deere 410 baler/problems
Peter
08-12-2002 01:20:09
My John Deere baler keeps plugging up on the left side of the baler. The hay builds up and then starts to wrap itself around the roller under the belts and stalls the pto of my tractor, would anybody know what causes this?? I've had the baler for years and only on occassion have had this problem before, this year for some reason it was happening all the time. Another problem is when the baler first try's to make a bale sometimes the hay wraps itself around the pick up roller also stalling the pto. Any tips would be appreciated. Thanks.
bob
08-12-2002 17:44:04
 Re: John Deere 410 baler/problems in reply to Peter, 08-12-2002 01:20:09
hay not dry...
Peter
08-12-2002 17:59:57
 Re: Re: John Deere 410 baler/problems in reply to bob , 08-12-2002 17:44:04
On one field the hay was down for a good four to five days before I could get to it and the baler was still plugging up?? Here in Eastern Canada this has been an exceptional dry season and even this late in the season the hay's down at least three day before I bale it, any chance it could be something else? I've had the problem before but never as bad as this year, I'm wondering if it could be the belt tension or something else because it's only the first belt on the left side that's doing it?? Thanks again for the help.
Bob Semrau
08-13-2002 06:45:51
 Re: Re: Re: John Deere 410 baler/problems in reply to Peter, 08-12-2002 17:59:57
Are all of your belts the same length ? Could this one belt be looser than the others ? You may need to shorten it some to match the others.
Bob Semrau
08-13-2002 06:45:19
Bob Semrau
08-12-2002 09:40:14
I have a 510, and this only happens to me when the hay isn't fully dry. These balers seem very sensitive to hay moisture. Sometimes if I'm baling too late in the day it will also do this, kind of signalling me that it's time to stop for the day ...
