Neat picture....now if you could just figure out how to hook that grownd drive rake in the right place ahead of the baler, you could save a go-over. Will try the block first..Like you, I think it should be able to flex some to avoid trouble! Actually my 860 is sort of designated as my rake tractor. Have a JD660 that I hook behind the JD650 to get a 'double' windrow and cut rake time in half. The 860 does pretty good with it, unless it happens to be one of those HOT days. Weight wouldn't be an issue.....got a full set of pie weights (minus one) on it, good brakes, just no power steering. My only tractor for about 10 years and got really aggravating when trying to get baling done when it was really hot, as the baler pulled more than the rake, would have to pullup under a shade tree and let her cool down. Wouldn't get into the red line, but would get to coughing, running rough, and lose a lot of power. About 2 years ago, got hold of the 2810 (a '84 model that had only a little over 500 hrs on it) about the same hp but diesel and power steering to boot, not to mention fuel economy. Figured even though it had the light front end style on it, being as I don't have a frontend loader, it would suffice until my ship came in and I could afford one of those new ones with a cab, stereo, a/c, etc.. :-) In the winter, that old 860 will work the 2810 into the ground (and make it like it!!) Have had to walk to the house and get the 860 a couple of times just to pull the 2810 out of being stuck moving logs for firewood that the 2810 just sunk with. If the 860 had power steering and would keep running good in hot weather, it would probably still be my only tractor and I'd be driving a newer model p/u!! Garry
