Sidewinder cutter any good ?
J T O
04-11-1999 17:21:50
I am looking at a Sidewinder cutter to purchase ,it is a 5 foot model , don't know model number , but it seems to be heavy duty, has a slip clutch...(used). Are they good cutters ? New price range? I can't find any dealers for these . thanks...
Sid Miller
04-12-1999 07:32:57
 Re: Sidewinder cutter any good ? in reply to J T O, 04-11-1999 17:21:50
I have a 6 foot Sidewiner.It is rugged as hell.It will mow what ever your tractor can handle.I use a 70hp tractor with mine. Make sure you have enough tractor for the mower.
Steve Hansen
04-11-1999 20:54:51
Sidewinders are very good rotary cutters. They were made by FMC. Particularly well sutited to working in the rough. They are heavy!!! Don't know what kind of a tractor you have but if it is a compact I suggest you hook up and drive around a bit with it before you buy. I had a 5' Sidewinder at one time. Just to much weight for my tractor. I replaced it with a 5' Howse. The model with the tire is very highly reguarded because it inertia it builds up helps it cut through saplings and brush better than the more common gear driven models.
Johnny Templeton
11-26-2004 18:37:52
 Re: Re: Sidewinder cutter any good ? in reply to Steve Hansen, 04-11-1999 20:54:51
Sidewinder cutters are excellent for rugged brush cutting. The tire drive absorbs shock to help protect the tractor. For additional information, please call Johnny Templeton, 731-645-1811 or email [email protected].
SIDEWINDER MANUFACTURING
07-20-2006 17:01:02
 Re: Re: Sidewinder cutter any good ? in reply to Johnny Templeton, 11-26-2004 18:37:52
SIDEWINDER IS STILL IN BUSINESS. THERE PHONE NUMBER IS STILL THE SAME 1-800-343-5825. YOU CAN GET PARTS OR MANUALS JUST CALL. OR ASK FOR A DEALER NEAR YOU.
Jimbo
04-11-1999 19:29:24
Yes Sidewinder made some excellent mowers. They are out of business, but parts are obtainable through Modern Mfg. in Beaumont, Tx.. The old tire driven mower they made has been purchased by a company called Gilcrest in Missouri.
SIDEWINDER MANUFACTUCTER
09-13-2006 10:52:32
 Re: Re: Sidewinder cutter any good ? in reply to Jimbo, 04-11-1999 19:29:24
CALL 1-800-343-5825 FOR ALL YOUR PARTS NEEDS
Sid Miller
04-12-1999 06:18:00
I have a 6 foot Sidewinder and did have one with the tire for a gear box. They are very rugged. They will mow anything your tractor can handle.I use a 70hp tractor for my 6 footer. Make sure you have enough power.
J T O
04-12-1999 21:45:40
 Re: Re: Re: Sidewinder cutter any good ? in reply to Sid Miller, 04-12-1999 06:18:00
Thanks a lot Sid , Steve , Jimbo !
