NH 479 question
rob
08-03-2002 17:43:14
Replaced the cutter bar in my NH 479 this morning, it had to be twisted just slightly to get the holes to line up, now it is eating those bolts about every ten minutes, Is there any adjustments that can be made and what is the proper bolt size and hardness, it is the bolt that comes up from the bottom and attaches the knife to the wobble box drive. I have to get a manual for this thing. Thanks in advance.
JMS/MN
08-04-2002 22:02:59
 Re: NH 479 question in reply to rob, 08-03-2002 17:43:14
Had a 479 from '75- '80. Sounds like you have a twist or misalignment between the gearbox and the cutterbar frame. They should be on the same plane. Never had any problem with that bolt. Is the gearbox bolted down firmly? No wobble in the drive arm?
