Disk question
WCreek
08-03-2002 17:29:43
When talking about a disk implement there are some numbers used to reference the size of the disk (2-14 for example). What do those numbers mean?
Brian in MO
08-03-2002 19:12:53
 Re: Disk question in reply to WCreek, 08-03-2002 17:29:43
A disk is usually refered to by how many feet wide it is (8',10', 12' etc) some use the number of blades instead of width because spacing is different. The 2-14 you refer to is a plow size meaning 2 bottom 14" furrows. Hope this helps Brian
Tim(nj)
08-04-2002 09:33:03
 Re: Re: Disk question in reply to Brian in MO, 08-03-2002 19:12:53
Unless it's a disk PLOW that is being referred to, when 2-14 means 2 disks, each one cutting a 14" furrow.
