Jerry,Posted back to you down below and forgot to ask a question about the feed forks that has had me puzzled from the first time I saw it and got to thinking about it....why was it built that way... Then got the manual out and started reading about it, and according to the manual...the inner feed forks are 'spring loaded' on a 'TELESCOPING' shaft to help prevent overloading of the bale chamber. On this ole 542, the telescoping shaft has been welded to the outer sleeve/tube, so that no telescoping action can be achieved. Not recently done iether...all the blue paint is the same faded shade, no evidence of any overspray, etc.. The man I bought it from said it was that way when he bought it (used) from the Ford dealership. I don't think he ever read the manual, said he thought the springs were to help keep the shaft straight... Again...don't have another one to compare it against..... is yours as the manual states, or has it been welded stationary? To answer your question below about the feed fork timing -- another WOW.....it is still working!! Forks appear to be timed right according to the manual, moved the hay across and into the bale chamber as they should with no problems... however.... apparently at some time in its life, the drive chain for the feed forks has broken (or was cut) at exactly the right length (no half links, and only one master).....the tightening sprocket was moved to the middle and SOMEHOW the master link was put back in with NO slack allowed!! Chain was so tight that it had wore grooves in the hood bracket where both upper edges of the chain has run - for who knows how long!! As luck would have it.....in this big little backwards town, have been unable to aquire a short piece of 2050 chain to splice in yet. Local NH dealership has just changed ownership/location etc..and hasn't got any on hand type inventory as of yet.....can order whole new chain, but didn't want to if I didn't have to!! Haven't had time to chase around to the other supply houses yet, might have to go to the next county as they are a little more ag inclined on keeping 'em running without going whole hog. Thanks Garry
