Need bushhog blades
Ludwig
07-24-2002 07:12:12
Its a Hesston Super 6. Hesston doesn't make rotary mowers anymore, sold the business to Toro, you ask Toro about it all they say is "Huh?"
So I need at least one blade, one had broke and we had a replacement made but its not the same, the old one had a drop so the cutting part of the blade was lower than the rest. The original was also pointy the new one is pretty square, and doesn't have a good edge to sharpen.
The mower works decent, but not great and if I ever break another blade I'll have to have more made and they'll probably come out wrong again.
If anybody knew where I could get one I'd appreciate it.
F14
07-24-2002 15:50:19
 Re: Need bushhog blades in reply to Ludwig, 07-24-2002 07:12:12
Curt, your best bet is to take the original into an implement dealer, and see how close they can come. As long as the mounting hole diameter is the same (assuming it's a pin mount) and the length is close to the same, it should work fine. Doesn't matter if it's a Hesston, a Toro, Woods or whatever, as long as it'll mount the same way and isn't too long.
