Bush hog
BrokeBlade
07-22-2002 13:26:41
I believe I have a bush hog brand. broke a blade. trying to put new ones on. finally got the nuts off but the bolts will not come out. Is there something I'm missing? Could it be rusted together that bad? Read a post about them being seized on there, is there anything I can use to unsieze it?
Stan
07-23-2002 10:44:02
 Re: bush hog in reply to BrokeBlade, 07-22-2002 13:26:41
I've used a good size punch or rod just a little smaller than the bolt diameter. Heat the metal where the bolt goes through with a torch so it's red hot. 2-3 good punches with the punch and a 10# hammer and they will come out.
Stan
Stan
07-23-2002 10:43:10
Stan
hay
07-22-2002 14:40:32
you might try to hammer on the bolts after heating them with a torch. that usually breaks the rust barrier. be safe!
