New Holland 268 Baler
Web
07-21-2002 07:27:59
A problem occured with My New Holland 268 Baler, everytime the Knotter completes tying the knot it shears the shear pin.I did not notice any visible reason of why this is occuring, I did notice at the time the knotter completes the knot the plunger is 3/4 of the way back and thats when it locks up and snaps the pin.I know my way around the baler pretty well but this time it has me stumped, any ideas or opinions on how i could fix it would be greatly appreciated.
Brandon
07-21-2002 16:54:34
 Re: New Holland 268 Baler in reply to Web, 07-21-2002 07:27:59
I sort of had the same problem with my 67. Chances are your knotter is out of time with the baler. Sounds like it is tieing too late and the plunger is hitting the safety latch on the way back. If you have a manual for the baler, it should tell you how to time the knotter. Solved all my problems, hopefully will solve yours too. Good luck Brandon
paul
07-21-2002 22:45:35
 Re: Re: New Holland 268 Baler in reply to Brandon, 07-21-2002 16:54:34
Exactly!
And if he tries to bypass the safty latch, the needles will be broken off....
Get it timed. It is very hard to properly describe in words; get a manual & follow the pics & words there.
--->Paul
JMS/MN
07-22-2002 23:09:40
 Re: Re: Re: New Holland 268 Baler in reply to paul, 07-21-2002 22:45:35
Timing might be the problem, but for whatever reason, the plunger stop is getting in the way of the plunger when the needles are in the bale chamber, protecting the needles from being broken by the plunger. Another possible reason is lack of lubrication of the linkage of the plunger stop. There are TWO zerk fittings on a vertical pivot between the flywheel and the bale chamber- part of the linkage. Make sure both are taking grease. They are accessed on the left side of the baler, about a foot? behind the flywheel. One is above, and one below, the flat steel member welded to the pivot.
paul
07-22-2002 23:49:34
 Re: Re: Re: Re: New Holland 268 Baler in reply to JMS/MN, 07-22-2002 23:09:40
You know, I don't think I grease mine often - thanks for the reminder!
There could be something slipped or damaged in the arm/roller/ needle cradle that is causing the problem too, not just a timing issue. I just had that on my 270 - when eating a big windrow, it would ping on the safty latch, barely catching it once in a while. I moved the roller stop about 1/16" of an inch (all the adjustment that was left) and it works fine again.
--->Paul
