Plough identification
Simon D
07-20-2002 07:34:48
Chaps,
I have just aquired a plough (I live in the UK) and would like to identify the maker so that I can find out if I can get hold of any spare parts.
Here is a brief description of the plough, if you have any ideas of who the maker may be then please let me know.
It is a three furrow non-reversible plough mounted on the three point linkage, I have a Fordson Super Major which it sits behind quite nicely. It has two adjustement levers one to rotate the bottom linkage arm to adjust the pitch of the plough in relation to the tractor and one to adjust the height of the land wheel. The frame is made from hefty rectangle section bar which has been bent and then bolted together. The ploughing blades themselves are mounted on large cast arms. What is lft of the paint appears to be a light blue color.
I hope that is enough detail, if any other destinguishing features would help please let me know.
With thanks in advance
Simon
Jerry S
07-22-2002 13:42:39
 Re: Plough identification in reply to Simon D, 07-20-2002 07:34:48
Simon, Lots of the plow you describe could be any of several makers of plows on this side of the pond. Being 3 point tells me it would likely have been made in the 50's or newer. Blue paint sort of points to a Ford in my mind. It is easier for me to say what it isn't. It isn't a John Deere or it would have been green with yellow wheels, An international would be red, and so forth. If that paint matches tractor makes you can identify with, chances are, that is your maker. Maybe there are some cast parts that have numbers or a manufacturer symbol in there. If possible, a picture is really helpful.
