New Idea Crimper Question
Errin OH
07-19-2002 19:39:18
I am in the process of replacing the roller bearings on my crimper (New Idea No. 750 lot H12A). I have found the removal of the old bearings to be almost impossible. I have distroy'd the two removed so far (metal roller). I have the numbers so getting replacements shouldn't be a problem. My question is should they be that tight? At this rate I will have to drive them on with a 20lb sledg hammer. The rubber roller apears to be in the same condition.
Harold Hubbard
07-20-2002 04:13:52
 Re: New Idea Crimper Question in reply to Errin OH, 07-19-2002 19:39:18
The old bearings were put on by Noah before he built the Ark, right? And they have been rusting ever since. I bet if you polish up the shaft and file out the big dings you put in while removing the old ones , the new ones will slide right on. Use a little oil.
