Saw a MM baler last night, comletely massive!
loren
07-19-2002 09:38:37
I couldn't believe the bulk of the thing. It's literally twice the size of my old Case 133. Looked to make about a 18"x20" bale. It had to be of a time right when automatic tying came about or maybe just after. This was on a fellas place that had 35 old tractors on 35 acres, and there were thick trees over most all the place. Must have been 10 Cub's, 6 or 8 Farmall M's, better than half a dozen F. A's, several H's, a few AC B's, a W-6 and more. Cool place to walk. Too bad most all were froze.
john d
07-19-2002 20:19:18
 Re: Saw a MM baler last night, comletely massive! in reply to loren, 07-19-2002 09:38:37
Back in about 1961 or '62, when I was still in high school and weighed about 130 lbs, we had a lot cattle to feed. We'd chopped our hay for years, but for a variety of reasons it was decided that some of it would be baled that year.
We didn't have a baler, but there was a man about 4 miles away that Dad knew well, and he got him to custom bale some alfalfa hay....
Fred arrived after lunch with a MASSIVE MM baler. I don't know if it was anything like the one you saw, but this beast was probably 10+ years old, and it was a tank. It had a Wisconsin V4 for power, a huge flywheel on the side, and tires well over 3' tall.
The day was hot, and when I saw the size of the bales it was making, all the joy went out of my young life. It made long, tight, lead-heavy wire-tied bales that weighed anywhere from 110 lbs and up.
About 100 yards into the first windrow, something broke, and I thought perhaps I'd gotten a reprieve. No such luck, Old Fred fixed that monster in about 15 minutes with a couple of wrenches and a big hammer. We started baling again.....
1100+ bales later, it was nearly dark, and the hay was in the barn. My job had been to unload the wagons into the elevator; I had handled every one of those bales, and felt like my arms were 6" longer.
That Moline baler was absolutely the hay-eatingest machine I have EVER seen in operation. Fred, Dad, and several of the others who made hay that day are gone now, but I drove past Fred's old place a few weeks ago and thought I could see part of that old beast peeking out of the weeds...
john d
07-19-2002 20:18:09
Bill
07-19-2002 20:12:29
I went up into Neb to get a set of cultivators fr My CC. They really for a Dc but they fit. I saw a MM Bailer there then. It had a hundred rods, gears ect that made the knotters work. Ill bet it was a pip keep running . On the otherhand maybe because it was so out and exposed, it was easier to fix, if just looking at it didnt scare you from buying it> I got a 1960 air cooled case 140 bailer im getrtng ready to run. Wish me luck
Hey, this is the first I've heard of a 140..
07-20-2002 08:44:01
 Re: Re: Saw a MM baler last night, comletely massive! in reply to Bill, 07-19-2002 20:12:29
Mine a 133 and haven't heard of many of them either. Broke both needle Sun and decided it better be time to replace the plunger wear slides. We put it back together yesterday and finished that bunch of hay, 295 bays out of 298 tied. I'm switching to 170lb. twice and so far it's working ok.
Bill
07-20-2002 20:40:09
 Re: Re: Re: Saw a MM baler last night, comletely massive! in reply to Hey, this is the first I've heard of a 140.., 07-20-2002 08:44:01
Ive got slight groves on the knotter fingers. rods that look like they have hooks on the, and a gear at the other end each. That causes therm tio mess up. I can put Never Seez on them and they wkll bale 2 doz bales before messing up again. Im going to try to take them off and get new rods for them
lc
07-20-2002 23:06:37
 Re: Re: Re: Re: Saw a MM baler last night, comletely massive! in reply to Bill, 07-20-2002 20:40:09
Are you talking about grooves on the duckbills where the string runs thru them? In making mine work better I filed a bit off the hook on the finger so that it could close farther and pull on the string better. Definitely improved the workings.
Bill
07-21-2002 05:25:56
 Re: Re: Re: Re: Re: Saw a MM baler last night, comletely massive! in reply to lc, 07-20-2002 23:06:37
Min es a 140-w meaning wire. I rather imagine they are somwhat different because of that.
