JD KBA disc
Richard Douthwa
07-19-2002 04:37:16
I have a KBA 6 disc harrow with a wheel carrier. This KBA has spoke wheels, which dates this disc in the 50's. When cleaning up the rims, JD571 was found stamped in the rim. The parts manual at the JD dealer shows 2 straight roller bearings, both the same part number. The hubs on these JD571 wheels appear to be made for a straight roller bearing for the rear bearing, and a taper roller bearing for the front bearing. I can not find any one that knows about the need for the two different types of bearings. Careful examination of the inside of the hubs does not show to be "wear", it appears to have been manufactured this way. I need help in finding the correct outer bearings for this wheel
I also would like the part number for the correct service manual, and parts manual for this KBA harrow. JD publishing sold me an operators manual, but it was for the newer style KBA with solid wheels(OMB 25040 issue B0).
