Sickle Sections And sharpening
Chris
07-18-2002 14:04:07
I would like for someone with more skill than i have (which is not any at all) Tell me the best way to sharpen a sickle blade i use a grinder but am hearing that its not the best way. Also what are the best sections for hay that has sort of a mix of grasses. Thanks for all your help.
Kermit in SW MO
07-19-2002 22:09:29
 Re: Sickle Sections And sharpening in reply to Chris, 07-18-2002 14:04:07
You can purchase a special grinding wheel that is made just to sharpen mower sickles. I have one though it is well worn and probably should be replaced. The last two years I've done it the lazy way and used my Makita right angle grinder to sharpen the sections. It doesn't put as precise an angle on the sections but they seem to cut the hay okay to me. Haven't been able to tell the difference. I use the sections that serated on the bottom.
Errin OH
07-19-2002 07:34:12
As little as possible. I use a 4" grinder and hit them just enough to put the edge back on. I follow the angle that was on them and sharpen them from the top side. I don't try to remove all the little nicks, just put the edge back on them. I use smooth blades and serated bottoms.
TomH
07-18-2002 16:41:07
Grinder should work okay. Just keep all the angles the same as they were. Replace any that are chipped or bent.
paul
07-18-2002 14:47:08
I like bottom-serated blades, or smooth blades, for grass hay. I find top serated blades plug up with the fine hay, especially if the ledger plates are also well-serated. But that's in my climate, my hay. Might be different for you.
--->Paul
