JD 1209 Moco
KWB
07-14-2002 04:35:16
Is the 1209 a good machine? What should you check out on a used one? Any other brands just as good or better for about the same money? Thanks in advance for any response.
Jim
07-16-2002 09:15:56
 Re: JD 1209 Moco in reply to KWB, 07-14-2002 04:35:16
Be sure and check the bracket that the wobble box(knife gear box) is bolted to is not welded or cracked loose from frame.If it is walk away from it.
Jim
07-16-2002 09:15:09
paul
07-15-2002 08:46:31
Mine sure likes to pick up rocks, get chipped sickles & bent guards. Also I hear the wobble box isn't the most durable out there.
But, it conditions hay well for me, other than rocks no problems in 3 years.
--->Paul
jim gutenberger
07-15-2002 07:24:30
In our dairy country of central Wis. the 1209 as to durabilty had a poor reputation. Was not built good enough for our purposes. The next models were improved and were considered much better fomocos. You can't compare a case 555 with a 1209 their is at least 20 years difference in tech. jimg
jim gutenberger
07-15-2002 07:22:48
Bill
07-14-2002 11:12:03
Hi, I have a 1219, a newer version of the same machine and I like it very much. Bill
JD70Jim
07-14-2002 07:58:55
I have a 1209. It replaced a CASE 555, which is the same as a HESSTON PT10, and believe me, there is NO COMPARISON. The 1209 cuts just about everything with no complaints, and the CASE (HESSTON) clogged continuosly. While a PT10 type of machine is pretty old now, it wasn't when my father had it and it still was a poor machine by comparison to the 1209.
Jerry D in NC
07-14-2002 05:27:42
I have the 1207 and it cuts great. Mine has cut thick heavy Orchard grass and thick alfalfa as well as some very thin alfalfa (thanks to no rain). Has cut everything I have put it into with no question. I have limited experience with MoCo's but this machine seems to have a solid reputation and you will get several responses here. Like anything else how it was cared for and maintained will mean more than anything else. With that said don't let the question I am about to start a thread on bother you because mine is a "Care For" issue.
