What is the best make in heavy duty rotary tillers
HH
07-13-2002 22:08:21
I am unfamilar with PTO driven Heavy Duty Rotary Tillers who makes a good 6 foot one for use with a 65 hp tractor?
Robert in W. Mi.
07-14-2002 17:54:25
 Re: What is the best make in heavy duty rotary tillers in reply to HH, 07-13-2002 22:08:21
third party image
Howard is the one to buy, and an HR20 70" would be a good match for a 65HP tractor. For "extreme" conditions, an HR30, like the one pictured is even heavier built, and rated for up to 100 HP. Either way, get the "Selectatilth" gear box, as it allows much more versatility. With Selectatilth, you can ajust the "tine speed" to the "ground speed". (4 speeds) This allows you to till at a faster speed to get more acres done per hour, or use a slower ground speed to get a finer seed bed! Hope this helps, Robert
HH
07-15-2002 19:09:08
 Re: Re: What is the best make in heavy duty rotary tillers in reply to Robert in W. Mi., 07-14-2002 17:54:25
Thank's, Robert
That is exactly the type of info I am looking for and it does help.
You wouldn't have any idea of the cost on one of these HR30 with the options you mentioned?
I just want to know if I should be sitting down when I ask the dealer. Also how is the availability on parts and cost on parts? High?
Thanks for the picture and the suggestions I wouldn't have though to set it up that way with out your suggestion.
HH
07-15-2002 19:06:23
Thank's, Robert
F14
07-14-2002 03:34:08
Howard Rotavator.
