Metal Pitman
Chris
07-12-2002 15:11:36
I am about to become the owner of a new idea trailer type sickle mower. I have used sickle mowers alot and wondering if anyone has made a metal pitman to use in place of the wood and how they got around the caps that connect it to the blade. Thanks for any suggestions
old fart
07-16-2002 07:58:11
 Re: Metal Pitman in reply to Chris, 07-12-2002 15:11:36
How about a reverse of this question, I have a Dearborne 14-16 mower that was made mith a metal pitman. It has been welded up about 3 times and I was going to get a new one from Ford/New Holland. They want over $100 Cdn. Now has anyone made up a WOODEN PIT MAN for this mower? Thanks guys.
old fart
07-16-2002 07:38:48
Jim in Michigan
07-13-2002 17:30:30
I made one out of pipe once for a mower,,, worked great,, but the price of a new wood pitman is cheap enough so I think wood is better,,, the one I made worked but was hard on bars...Jim
William Ransom
07-13-2002 16:26:02
third party image
My father made one for a New Idea 251. Nothing broke, but one of the parts connecting the pitman to the blades bent. I took this picture after I straightened the bent part.
Jim.UT
07-13-2002 16:11:03
Don't replace the wood pitman with metal. Did you ever stop to wonder why an implement manufacturer with a staff of design engineers would make a mower out of nothing but steel and cast iron; except for the pitman? There must be a good reason. And there is. Read the other reaponses below.
Doug in OR
07-13-2002 15:40:58
I suspect that the metal will be so heavy, compared to the wood, that you'll not be able to overcome the balance problems.
ELTON
07-13-2002 14:50:44
I have a New Idea trailer type mower that has a 9 ft. blade. I believe that it is a model 253. I have been unable to find a pitman. Do you know where to get parts. By the way, stay with the wood.
kraig WY Yeah I made a metal pitman arm
07-13-2002 13:15:06
On a horse drawn mower. Tore the he!! out of the mower. Sure glad I didn't try it on one hooked to the power take off. Woods cheaper then mower parts.
Jerry D in NC
07-13-2002 11:56:48
The wood pitman is the "Fuse" for the mower. It saves the mower when it hits something it shouldn't cut.
ErnieD
07-13-2002 11:13:08
I would stay with wood. The wood beaks protecting the drive train.
