Servis brand brush hog
Two Bit
07-12-2002 09:40:41
I have a "Servis" brand pull behind 5' brush hog. The model number is "U". Plate says it was made by Servis Impliment Co. in Dallas Texas. I use it with my Farmall H (it came with tractor when I bought it). The mower is a little beat up but still mows OK. Just wondering if anyone has heard of a SERVIS mower or the company or had any idea of the year. It is old. I would like to know if that was a common brand or just a local company no longer in business. I grew up in Dallas area but never heard of SERVIS IMPLIMENT CO. and have not found any info on them.
Two Bit
07-15-2002 05:54:35
 Re: Servis brand brush hog in reply to Two Bit, 07-12-2002 09:40:41
Thanks for the replies and the great information. I'll need to replace the lower seal of the gearbox and plan on taking the old seal out and take it to a good bearing/seal shop or napa to get one to fit. Looks like Rhino is another option for parts.
gy3020
07-14-2002 11:36:07
In my opinion Servis(now Servis/Rhino) is the best mower made. I have an uncle who has a older drag type, I have a Gyro 1310(14 ft. cut) an have had a 5ft. 3pt(1986 model) and fully intend on gettin another one day. The King Kutter 5ft 3pt I have now is filling in the gap but a Rhino is the mower of choice, built like a brick out house(strong that is)
Gene Kilgore
08-28-2003 15:41:23
 Re: Re: Servis brand brush hog in reply to gy3020, 07-14-2002 11:36:07
I have a 1310 Servis-Rhino rotary cutter. I do not have a parts manual. I am having trouble timing the left gear box. I get it adjusted and then the blades hit again. I need to know how you disassemble the gear boxes. Does the gear come out the top and are they keyed? If you could be of any help or have a parts manual, please contact me on here or at [email protected]. Tha
Rodger
05-04-2004 20:27:48
 Re: Re: Re: Servis brand brush hog in reply to Gene Kilgore, 08-28-2003 15:41:23
I have a 1310 that I am rebuilding. I have replaced gears in one gearbox and cleaned the others. I'm half complete with replacing all seals on the mower. NAPA, Alamo (Servis-Rhino parent), and a local gear store are good for seals. The gears have a keyway. The spindles are not splined. These gears are pressed in. The gearbox housing is sandwiched between a gear and a bearing. I'm looking for a tool to tighten the locking nuts (I have new ones.) on the spindles. The "time honored" way of tightening them has destroyed the old ones. Does anyone know where to get this tool?
Your post was fairly old when I saw it, but I can tell you what my manual says about timing. The operator's manual, the third edition, was printed 5-15-73 for the Gyro-1310.
Blade Timing and Rotation
"The Blade Carriers are timed at factory by a method you too can follow if field repair work is necessary and re-timing required. FIRST, by means of a hoist fastened to front of cutter, raise the cutter frame to a secure vertical position. (It will be of advantage to disconnect the axle, etc., and let rear of cutter frame rest on ground for stability). With cutter thus upright and viewing the under side, align the Blade Carriers in relative position so as to resemble the letter "H". This may be done by aligning the carriers, by sight, with the several underneath, Frame-Cross Members. SECOND, walk around to opposite (Top) side of cutter frame and note the relative positions of the Flexible Coupling Spider Yokes of Gear Boxes. Hold up the Flexible Coupling Drive Line and compare its bolt locations with holes in Gear Box Spider Yokes. If necessary to adjust for fit, slip the Spline Shaft out of Splined Housing, rotate as required, re-engage and bolt in place. SUGGESTION: Fasten Right Hand Flexible Drive Line in position first. Follow the same procedure for the Left Hand Drive Line. NOTE: If perfect 90-degree relationship of Blade Carriers cannot be obtained, adjust the Drive Line one notch, so that the Left Hand Carrier will lead slightly in direction of rotation."
The only diagram is the top view of the mower. I'll try to describe it. As the mower is hooked to the tractor, viewing from behind the mower, the left blade carrier will be on your left. It has counter-clockwise rotation. The center blade carrier also has counter-clockwise rotation. The right blade carrier has clockwise rotation.
I hope this can be of help to someone else if you have already figured it out. I have not timed my blade carriers yet, but I think I can do it without the hoist.
I have a question: You should have a Morse Torque Limiter 700A on your Servis 1310. Do you know if it is the 700A-1 or the 700A-2? Morse described the 700A-2 as being the same as the 700A-1 except for an extra disk spring on the -2. My limiter has the stamping "Morse Torque Limiter 700 A" on the hub, but anything else is obscured by the years of use it has seen. It does have an extra disk spring, but my limiter may have been modified. I'm trying to get the right one so it lasts another 30(?) years.
Thanks for any information you might have.
David
07-12-2002 10:41:58
Servis was incorporated on December 18, 1930 in Texas as Servis Equipment Company, a wholly owned subsidiary corporation of Austion Bridge Company. Servis was organized to maintain equipment for the Austin construction companies and gradually started designing and manufacturing construction equipment such as rollers, packers, and road graders from the middle to late thirties. The first semi-mount, hand-adjustable road grader blade was produced in 1934. They are now part of the Alomo group. On June 26, 1986 Alamo Group Inc., based in Seguin, Texas, purchased all the assets of Rhino Products, Inc. BMB, Inc. in Holton, KS to provide much needed manufacturing capacity for the Rhino product line. Here is a link.
Burrhead
07-12-2002 12:24:38
 Re: Re: Servis brand brush hog in reply to David, 07-12-2002 10:41:58
outside of what David said yes they are a very good brand name. They go by either Servis or some of them go by Servis/Rhino or just Rhino.
