King cutter bush hog
steve19438
07-10-2002 11:18:34
what should i expect to pay for a used king cutter bush hog in good condition. it mows well and the deck is in good shape. cutting width is five (5) ft. the color is blue with white letters if that helps date the machine.
thanks, steve
RB/CT
07-12-2002 08:59:00
 Re: king cutter bush hog in reply to steve19438, 07-10-2002 11:18:34
This area (CT) is high priced for used equipment. a local dealer told me that what a fair price for used equipment is half the original new price. Many things factor in, but you could always go up on a low offer.
Bill
07-10-2002 19:52:34
The brush hogs out here go between 350 & 450 depending on make and condition. Keep in mind a new King Kutter is 649.00 for a 5 foot model. I would also contact your local rental yards. I just picked up a heavy duty 5 foot model that was used for 2 years and they sold it for 175.00 with a pto shaft with slip clutch. I am also looking a a 48" tiller from them for 195.00.
Just a thought. Bill
Bill
07-10-2002 19:46:19
Bill
07-10-2002 19:43:16
Charles Story
07-10-2002 12:09:51
I put my 5' King Kutter bush hog thru all sorts of thickets/brush/trees/stumps, after 2+ years of abuse it is still holding up. Only problem I had was, the bolts holding gear box to frame loosened up. I retightened thosed and back to cutting, that was over a year ago, they are still tight.
I also have a 5' sidewinder hog, it has a larger gear box, it works great also. Good Luck.
Dino
05-09-2004 09:59:04
 Re: Re: king cutter bush hog in reply to Charles Story, 07-10-2002 12:09:51
Speaking of loose bolts holding the gear box to the frame, is there any way to tighten those without taking off the belly pan & blades?
These bolts are loose on my 5' King Kutter & so far, that's the only way I see to do it.
Any other ideas, etc. will be appreciated.
Thanks,
