Mower PTO too short
JerryinPa
06-28-2002 09:26:49
I hook up a JD #9W sickle bar mwoer to my 3 pt hitch and the pto is about 2 or 3 inches too short. Do I need to buy a longer one or is there some adjustment I can make. Its going on a Cub Cadet 7272 27hp tractor.
Thanx
Jerry D in NC
06-28-2002 18:05:26
 Re: Mower PTO too short in reply to JerryinPa, 06-28-2002 09:26:49
Places like Agri-Supply sell a PTO extension of about 6" for <$20. Look around they are called PTO Extensions.
TomH
06-28-2002 16:24:53
By too short I assume you mean the two pieces of the shaft come apart before they reach? Shouldn't be a problem to get a longer shaft, but it seems odd that it won't extend far enough to reach to PTO, usually they have a lot of overlap to work with.
Gary
06-28-2002 10:39:30
I don't know anything about your mower, but you could probably put an over-running coupler on the tractor pto shaft and solve your problem.
Good Luck,
Gary
