New Holland Haybine
Josh
06-27-2002 19:22:48
The haybine on the farm I work on has a problem with wrapping hay around the rolls while working in the field. What would be a possible cause and remedy for this situation? We're planning on cutting a lot of hay this weekend, so a response as soon as possible will be greatly appreciated. Thankyou for your time. JKK
Jon D
06-28-2002 18:20:31
 Re: New Holland Haybine in reply to Josh, 06-27-2002 19:22:48
If it's a disckbine, we're having the same problem... We've found that if you adjust the plate above the rollers up so the hay is thrown higher, helps somewhat.
Craig MO
06-27-2002 19:51:03
It depends on what type of hay you are cutting and what type of conditioner you have to give best answer. If cut hay wraps around conditioner rolls look for tension adjustment on rollers or reel set at improper height or fore an aft adjustment on the reel.
JOE in MO
06-28-2002 08:17:14
 Re: Re: New Holland Haybine in reply to Craig MO, 06-27-2002 19:51:03
Please get a manual, it will discuss properly setting up the rollers based upon the type of hay you are cutting, I broke my older Hesston haybine, which was doing the same thing until it clogged and broke the belt, (it was a older belt anyway), but my manual came in finally from the dealer, and I discovered it was imporperly set the rollers were set too low for my cut, (orchard grass), as well as too much tension, it was a matter of time for it to clog and break, but look at the manual and make sure you adjust your rollers as well as the reel that pushes your hay into them. Good Luck..
Josh
06-28-2002 04:26:15
Thank you for your reply. We are planning on cutting timothy hay this weekend but it is knocked down pretty good due to rain. Previously it was orchard grass that ended up wrapping the rolls. I was thinking and I think the haybine has the model #469, I'll know better after today. Thanks again
David Berger
06-29-2002 11:28:29
 Re: Re: Re: New Holland Haybine in reply to Josh, 06-28-2002 04:26:15
New holland #469?yikes my neighbors got one of those.its a peice.he just has one of his friends cut down his hay with his discbine.lol
