JD Mower
JerryinPa
06-27-2002 09:05:32
I just bought a JD #9W sickle bar mower and it need a swath board. What function does a swathboard perform?? Also, where can I get an operaters/parts manual for this mower. None listed on this site.
Ken
10-19-2002 09:50:40
 Re: JD Mower in reply to JerryinPa, 06-27-2002 09:05:32
Do you know, hopefully, if the J.D>> # 9 mower will fit on a J.D. 920?
Jim in Michigan
06-28-2002 12:16:19
I have a JD mower that the swath board was broke on,, I just built one out of wood myself,,works great and looks nice too...Jim
DaveinNY
06-28-2002 02:21:26
We have a #9W on an 8-N Ford thats mowed a lot of hay.It works a lot better than the Ford mower it replaced.You need swath board for sure,especially in heavy hay.Check your local J.D. dealer for manual.This mower is old enough that Deere won't have some parts available."been there" Good Luck
Fudd@Work
06-27-2002 20:39:38
You can order manuals from JD but I don't have the number here. Ask over on the Deere board. Tractor Supply can sell you a swath board.
Fudd@Work
06-27-2002 20:37:43
Stores like Tractor Supply have swath boards. Ask over on the Deere board for the JD number to call to order manuals. They will have one.
Jim.UT
06-27-2002 11:43:15
Big Dog is correct. I recently broke my swath board in the middle of cutting my hay. Made a noticeable difference. I will be making a new board shortly using the old one as a pattern. New ones are available from JD dealers, but the cost is laughable. A piece of plywood and a saw will get you one quick.
I believe manuals are also available from the dealer.
Bigdog
06-27-2002 10:50:28
Jerry, The swathboard was to make the end of the just-cut swath lay over onto the cut grass rather than laying on the un-cut grass. This leaves you a clean, visible line between cut & uncut crop.
Jim Broughton
06-27-2002 23:04:19
 Re: Re: JD Mower in reply to Bigdog, 06-27-2002 10:50:28
Jerry: I believe "Binder Books" in Tigard, Oregon have manual reprints for your mower.Their phone number is; (503) 684-2024 or you can "fax" them at 503-684-3990. Like the others, I simply made mine out of a piece of plywood and my electric Jig-saw, complete with the round staff on the end so you can see the end of your mower in tall grass. I painted it real good with three coats of yellow paint and it has served me well for the last two years and still looks good! Lots of luck on your project ! Jim
