JD 14T making curved bales
Chris Brown
06-23-2002 20:41:39
no matter how I set the cranks it still curves to one side,bales are tight and heavy and just a little crooked.I htought if it was curving to one side you loosen the side it's curving toward and tighten the other,doesn't make much difference.bales handle OK but would be nice if they were straight.we are useing an automatic loader and a few bales bust when they hit on the curved side.the bales curve toward the twine box side.any suggestions?
thanks.
Chris Brown
06-25-2002 20:34:34
 Re: JD 14T making curved bales in reply to Chris Brown, 06-23-2002 20:41:39
It was the vee notch hay check plates .One side was rusted almost gone.thank you all very much,made 361 bales today
ErnieD
06-24-2002 15:28:41
If all else fails pull all the hay out of the bale chamber and look for accumulations stuck to the inside of the compression chamber. Happened to me once.
Tim(nj)
06-24-2002 07:09:17
It is also possible that your feeder fork is out of adjustment and is not delivering hay far enough into the chamber. One of my 336 balers had that problem, same basic setup as 14T. Do you have a manual that explains fork adjustment? If not, head to the JD dealer to get one.
larry va.
10-15-2002 18:01:21
 Re: Re: JD 14T making curved bales in reply to Tim(nj), 06-24-2002 07:09:17
check your plunger knife and feeder forks.run faster ground speed so your baler can get enought hay to make a nice squire bale.slow speed makes curve bales unless you have large rows of hay.
ET
06-24-2002 06:43:14
There are suposed to be some things I think are called hay restrictor or resistors in the front of the bale chamber. They make the bale pack evenly.
The one in the bottom looks kind of tike a Vee wedge. I hope this helps.
ET
06-24-2002 06:39:21
ET
06-24-2002 06:32:21
Fudd
06-23-2002 21:49:51
My 14T liked to do that till I removed the stationary knive and the knife from the plunger and sharpened them really good.
Loren
06-23-2002 21:28:59
My old relic of a case will banana when I don't feed her consistent and heavy enough a windrow. Just a thought.
what Case??
06-28-2002 10:17:50
 Re: Re: JD 14T making curved bales in reply to Loren, 06-23-2002 21:28:59
what kind of old case do you have?
Loren
07-01-2002 14:47:15
 Re: Re: Re: JD 14T making curved bales in reply to what Case??, 06-28-2002 10:17:50
a 133. Was told it's somewhere around '57 or a '58.
