NH 67 bailer
Mark
06-22-2002 20:21:19
Have a NH 67 bailer keeps braking shear pins .Hear a loud noise when it trips or knots for a new bail.brakes pin every 3 bails
Thanks
Mark
Craig MO
06-23-2002 18:39:23
 Re: NH 67 bailer in reply to Mark, 06-22-2002 20:21:19
Either the plunger stop is not fully retracting or more than likely it is out of time. Place plunger crank arm between chisel marks or edge of baler case or in a vertical position. Pull arm on right side of baler that runs the needle carrier back or in the home position. Three dots or a chisel mark on left knotter drive should line up. If not lossen chain and move to get marks lined up. Tighten up chain and see if marks are still lined if they are baler is timed.
Dave, Sherburne, NY
06-23-2002 17:24:25
You lucky its breaking shear pins , it could be the needles. Probrobly the chain that drives the Knotters is worn out and its jumped time or close to being out of time. The plunger stop is apparently not rusted , and stops the plunger from breaking the needles when it tries to make a bale.
