I posted a while back about a spreader on which the chain driving the horizontal auger was slipping part way off the sprocket and locking the wheels, or slipping off all the way. There were a number of good suggestions, and I finally got around to pulling the gaurd off and seeing what needed done.The chain does, in fact, have a tension adjustment, but it is adjusted as far as it will go. The chain is clearly too long - presumably stretched since the spreader is like me...old and tired. The chain is made of links that are formed from flat steel, probably a little less than 1/8" thick. The links are around 1-1/2 to 2" long and the only thing I can see stamped on them is a nunmber 55 on each link. I don't know what a new chain would cost -it has 30 links - but I'm half Russian and half Hungarian, plus about 95% scotch, so my first inclination is to remove a link. My wife and her mother - both farm gals - definitely remember dad/hubby removing links from such chains. It looks to me like I could spread the connection with a cold chisel enough to remove a link, and probably bend it back with a carefully applied hammer or press, but they are convinced there's an easier way, and I feel sure that if I can open and close them, they aren't hard enough to last long after that. Can such a chain be shortened? Or am I really looking for trouble trying to do that? Your advice would be appreciated.
