Kuhn Disc Mower
Mike
06-12-2002 17:19:47
Found a Kuhn disc mower and stopped by to take a look at it this afternoon. All looks ok for it's age and use but the one thing I did notice, which may be a problem, is the joint where the cutter bar attached to the 3 point section has slack in it. Enough to where if you look down the belts you can see the pulleys aren't quite aligned with each other. That is, the top pulley or the one in line with the PTO is straight and the one in the joint is off by a little. If you're standing on the end away from the cutter bar looking down the belts, the side of the pulley in the joint nearest you (or away from the cutter bar) would be toward the tractor. Hope this makes sense. Question is, is this pretty typical of older disc mowers? Could this be a real problem? This has me undecided on what to do and I have to admit, I did have my hopes up on actually finding a mower. Any help appreciated.
Thanks in advance.
cannonball
06-13-2002 05:16:44
 Re: Kuhn Disc Mower in reply to Mike, 06-12-2002 17:19:47
the bushing probably wore out on the back and front and let the gear box ends wear ...would cost about $100 each end if you relace them yourself...i let the rear one wear out before i replaced it had to repace gear box housing...just work involved...hope this helps..... ...may god bless
