Making a drag out of Chain-link fence
Cary
06-10-2002 10:00:08
Hey, I've got some old chain link and was thinking about making a drag to pull behind the tractor to level with. Anybody got any suggestions? The thing I keep trying to figure out is how to put enough weight on there. What about attaching to 4x4 posts somehow? Thanks!
Kerry
06-11-2002 20:42:01
 Re: Making a drag out of Chain-link fence in reply to Cary, 06-10-2002 10:00:08
third party image
I made a drag out of several old tired tied together in the shape of the Olympic rings. I use a chain to pull it behind my 3-point 6-1/2 ft disk. I'll try to post a picture if I can make it work!
Kerry
06-11-2002 20:34:11
third party image
Tom
06-11-2002 19:28:06
Do you build a pipe frame and attach the wire to the pipe are how do you make one? I need to build one if they work that good. Will they level plowed ground or smooth out the ridges left by a disc? Let us know how it works.
nebraska sasquatch
06-10-2002 20:32:50
I used a feeder house conveyor chain from a combine, it weighes alot by itself.
nebraska sasquatch
06-10-2002 20:29:23
Jim in N.S.
06-10-2002 14:55:09
Used to work for a construction co. and had access to old crusher screen's. They were great for leveling topsoil.
Charles Story
06-10-2002 10:35:24
They work great, so do old bed springs with used tires attached for weight.
Cary
06-10-2002 11:24:39
 Re: Re: Making a drag out of Chain-link fence in reply to Charles Story, 06-10-2002 10:35:24
What about something to attach it to? Assume you'd just make a loop of chain at the front to attach to the draw bar?
Festus
06-10-2002 17:44:40
 Re: Re: Re: Making a drag out of Chain-link fence in reply to Cary, 06-10-2002 11:24:39
Yes, I just use a tow chain with hooks on both ends.
Festus
06-10-2002 10:25:30
I use a chain link fence for a drag on my food plots. Works very well. If you have enough fence, just roll most of it up and wire it so it won't unroll. It's pretty heavy rolled up.
jim
06-10-2002 14:53:21
 Re: Re: Making a drag out of Chain-link fence in reply to Festus, 06-10-2002 10:25:30
They've used chain-link fence up here for years when preparing baseball fields before a game. Works great!
Jim
06-10-2002 16:57:20
 Re: Re: Re: Making a drag out of Chain-link fence in reply to jim, 06-10-2002 14:53:21
Will work fine. Wire old tires on and will be enough weight.
