Part No. for belt
ScottyNY
06-07-2002 18:39:56
HEEELLLLPPPPP! I'm about at wit's end. I have an old McCormick 21 sickle bar mower that was on the back of my SuperC when I bought it, a selling point, really. Been all up and down central NY getting new cross joints and everything is running, but I need a belt. The existing one is cracked and stretched and may not have been the right belt in the first place. The bearing box is topped out and the bolt that holds the adjustment is as far as it will go. It's the same dimension as the Gates C series belts, but the shortest Gates makes is 55" The old belt that is too long measures out at 54" Any body have a NAPA or other number that is equivalent to what I need? This is for the high-speed flywheel (that is about 12"--the low speed was 10-10-1/2). Thanks for any help. Scotty
JMS/MN
06-07-2002 21:02:23
 Re: Part No. for belt in reply to ScottyNY, 06-07-2002 18:39:56
Run a tape around the outer edge of the pulleys and measure the distance. Check with a belt supplier, sounds like you already know the width of the belt. Any IH dealer should also be able to find the correct belt.
