Torque
Doug Rogers
06-06-2002 05:31:32
Does anybody know what the torque needs to be on the bolts of a skid brake on a John Deere baler? I don't know if "skid brake" is the right term but its the brake that the PTO drive line goes into.
Catskill Pete
06-06-2002 16:26:32
 Re: torque in reply to Doug Rogers, 06-06-2002 05:31:32
The SLIP-CLUTCH on JD balers is adjusted by measuring the spring length not bolt torque. On my 336 the measurment called for is 1-21/32 [42mm] if it still slips too much it can be tightened more, but not shorter than 1-19/32[40mm then you are supposed to replace the springs. You didn't say what model you have, but those figures would be a good place to start until you check with your JD dealer.
Catskill Pete
06-06-2002 16:25:45
how tight JD baler slip clutch?
06-06-2002 10:13:06
I don't know, but that's the question I'd ask.
--->Paul
Doug Rogers
06-06-2002 10:21:54
 Re: Re: torque in reply to how tight JD baler slip clutch?, 06-06-2002 10:13:06
Thanks. That's what I meant.
JMS/MN
06-07-2002 21:06:30
 Re: Re: Re: torque in reply to Doug Rogers, 06-06-2002 10:21:54
Also make sure that each bolt is adjusted the same amount, and any changes are made equally on all bolts, to maintain equal pressure around the plates. Generally slip clutches should be adjusted to hold the load under average conditions, plus just a skooch more! Overtightening just breaks more parts.
thurlow
06-08-2002 13:46:31
 Re: Re: Re: Re: torque in reply to JMS/MN, 06-07-2002 21:06:30
Is a skooch more or less than a smidgen??
