Ruined gearbox..?
Homesteader
06-06-2002 05:04:30
Would anyone out there have any kind of diagram, picture, or whatever of the workings of the gearbox on a Howse 500 bushhog? I believe I've got some ruined gears after a bad encounter with a stump, but would like to know what I'm going to find when I open it up. Thanks for your help.
Karl in MD
06-06-2002 10:50:58
 Re: Ruined gearbox..? in reply to Homesteader, 06-06-2002 05:04:30
I used to sell (regrettably) Howse mowers. More than likely the teeth are gone off the output shaft gear. If it stopped dead, the box itself may be okay, and you would just have to flush it out clean to get the debris out and replace the gears and bearings. If it turned at all after the "kaboom" there is the possibility of broken teeth, etc. getting in where there is no clearance and cracking the housing. A thorough inspection is in order in either case. E-mail me if you have other questions. Karl.
